Community Member
CUC not see caller ID for external calls
I am running Unity Connection v8 ( we have same problem with v7 on another site )  and am trying to fix the problem with caller ID for external calls . When i get a call from external line and caller leave voice mail message the caller ID  should be visible on the message on IMAP and play in message option ( if i configure this) , but i get this line in header -"Message from Cisco Unity Connection Messaging System (Unknown extension)"
this is output from CUC debug , looks like call come in to CUC with caller ID ,
[callerID='0871233333' callerName='087123333' calledID='1942' redirectingID='1942' lastRedirectingID='1942' reason=4
this is configuration Outside Caller Messages " %D% %U% %P% Message from %NAME% (%CALLERID%)" for subject line format
is any idea what missed in configuration ?
Thanks for any thoughts you can provide!
Community Member
Re: CUC not see caller ID for external calls
I am having the same issue on a new 8.x install. Did you ever figure this out?
Community Member
not remember what exac we changed , but now Subject line format looks like in att
Alex
1550
