CUC SIP MWI
I have a CUC version 10 with sip integration to cucm version 10. Some phones mwi works fine others nothing I cannot see any issues as we can leave messages etc   If I go inti the USR / MWI Setings and do a reset all the mwi starts working.
Any ideas?
Any help would be great
Hall of Fame Super Silver
Do you have sufficient number
Do you have sufficient number of ports defined for MWI on CUC side?
Chris thanks for reply. I
Chris thanks for reply. I have 200 ports what I did find out the Publisher is running but the Connection Notifier is deactivated on the pub and started on the sub.
I suspect since I cannot activate thru cli that a make primary and back will need to be done.
Thoughts?
123
