11-23-2011 07:02 AM - edited 03-16-2019 08:12 AM
Having CUCI-Lync 8.5(2) activated on the desktop, using MS Office 2010, when selecting cells in 3 different sheets causes Excel to crash. When CUCI-Lync disabled it works well.
Can anybody help me or confirm this matter ?
Thanks in advance
Guy
Solved! Go to Solution.
11-23-2011 09:03 AM
Guy,
I have not heard of Excel crashing, but there was a known issue with Outlook 2010 crashing which supposedly is fixed in version 8.5.4 that was posted few days ago, you may want to give that a try.
Chris
11-23-2011 09:03 AM
Guy,
Chris
11-23-2011 10:18 AM
Thanks Chris,
Thanks a lot for your answer.
We are not able to reproduce the issue on our lab but we'll try 8.5(4).
On the customer's laptops:
Open Excel.
Right-click on Sheet1 -> Select all sheets (I expect its the good name, we are in French version)
Then click on column A select up to column G
Enter anything -> Excel frozes and takes an appearance with large bars and crashes.
Guy
