CUCIMOC - active conversation window
Hey guys,
at the moment we have a problem, with the „Active Conversation“ window from the CuCIMOC client.
I use the callmanager 8.0.3.20000-2 and we are using the LDAP directory for the CUCIMOC clients.
I have added same screenshots for you. "see below"
And I hope that you can explain to me, where and how I can configure the „Active Conversation“ window.
CASE 1 (This is OKAY)
Call from a Cisco telephone to the Cucimoc Client (internal Call).
Here you can see everything in the Active Conversation windows is right.
CASE 2 (WRONG NAME)
Internal call from a CUCIMOC client to another CUCIMOC client.
But if an internal CUCIMOC Client is calling another CUCIMOC client, you see that the wrong name is shown in the Active Conversation field.
CASE 3
Call from a CUCIMOC client to an external number or internal number.
This is the same problem like CUCIMOC to CUCIMOC, in the Active Conversation field you see the wrong name, again.
CASE 4 (This is okay)
An external Call to a CUCIMOC Client.
In this case everything is fine.
CASE 5
If CUCIMOC client is using the Active Directory Search to find a participant,
the Active Conversation field shows the right name, but there are 3 participants entries.case 5.jpg
And now I hope that you can explain to me, what I have done wrong during the installation.
Greetings from Germany :-)
Re: CUCIMOC - active conversation window
Hi Janos,
This issue needs to be narrowed down as much as possible
Under which circumstances does this happen ?
Only when we receive calls to Cucimoc from external  / internal (Cucimoc)  ?
Does this happen to all users or only to some of them ?
Is there any similarity of the DN's between the calling and called party ? (ie internal DN 12345 and external dn +77 4312345)
Do you have any directory lookup rules configured ? Can you check if we hit any of those rules ?
Christos
Hey Christos,
it take me a long time to check it, but in the end I found the problem.
It was my translationpattern, which was not configured correctly.
Many Thanks to you. :-)
Thanks for posting the answer here Janos.
It's appreciated!
Christos
542
