CUCIMOC without CUCM AD Integration?
Is it possible to utilize CUCIMOC without having our CUCM integrated with AD?
1 ACCEPTED SOLUTION
Red
Re: CUCIMOC without CUCM AD Integration?
No.  That is NOT the only place.  You still have to populate other settings, like TFTP, CTIManager, etc.  Please check with CUCIMOC docs:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucimoc/8_0/english/installguide/cucimoc_install.html
Michael
I am sure Michael will pop in and set me straight but I believe the answer
to your question is yes.
HTH.
Bill
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Well, I hope he pops in with more info.  Anyone provide a top down basic scenario on doing this w/o LDAP integration?  Everything I see in documentation seems to require AD integration.
It requires AD, without AD you won't be able to log in to OCS communicator , and without this you won't be able to run CUCIMOC .
greetings
Marcin
Red
CUCM does not have to integrate with AD.
CUCIMOC login is separated from MOC login, which means you may use different credentials for each login.
CUCIMOC uses AD for name-to-number resolution.  But the integration is between CUCIMOC and AD.  Not between CUCM and AD.
Michael
http://htluo.blogspot.com
So what am I missing?  I installed CUCIMOC, but I am getting and error " A device initiliazation error has occurred.  Failed to connect to the CCMCIP authentication server"
I assume I need to point the cucimoc to CUCM, but not sure what to do.
Red
CUCIMOC uses the configuratoin in registry.
You should have a sample BAT file from the download zip.  Modify the value of the BAT file and run it.  There sould be CCMCIP in the BAT file.  You should point that to your CUCM publisher.
If your CUCM is using 3rd-party certificate, additional configuration is required.
Michael
Michael, thanks for pointing that out.  I have the admin zip file and the BAT file.  Is the CCMCIP the only place I need to change IP address?
Red
Michael
Got it and hit you with 5 stars.  Thanks
576
