CUCM 10.5(1)SU1 synchronization with PLM
I have PLM running co-resident with a CUCM Publisher version 10.5(1)SU1.
When I add or delete devices to CUCM then sync PLM the number of Installed devices shown in PLM does not change.
Does it take a while to sync? - the PLM GUI says the sync is successful so I would have expected that the PLM data would be updated straight away.
Has anyone else seen this?
1 ACCEPTED SOLUTION
Hi James.Did you try to go on
Hi James.
Did you try to go on System --> Licensing --> License Usage Report and click on Update Usage Detail Button and than re-synchronize PLM?
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi James.
Let me know
Carlo
Thanks Carlo, that fixed the
Thanks Carlo, that fixed the issue
170
