CUCM 10.5 bulk export universal line template
jeff.msweet
I'm trying to export universal line templates and universal device templates from bat.  I've found that even though there isn't a specific category for these the universal device templates are exported with a phones export, however I can't find where the universal line templates are exported.
Does anyone know if exporting universal line templates are possible?
6 Replies 6
Jonathan Els
Level 5
Level 5
Hi Jeff
Did you ever come right with this one?  I have scripted auto-generating BAT files for everything else.  This is the last thing i need!
 - Jon
Unfortunately not possible as of now, Bug is still in an Open state:
https://tools.cisco.com/bugsearch/bug/CSCut91558/?reffering_site=dumpcr
Deepak
Thanks Deepak, missed that one!
There is a workaround for the UDT's, that can be loaded with BAT using the phone loader.  However, they are caveated in that the line-related information can't be added.  I've thought about looking at a sql update for the UDT line info, but I haven't dabbled enough with this yet.
That might be an option, post at below thread and you might get one
http://www.ucguerrilla.com/search/label/CUCM%20SQL%20Query
Deepak
Thanks, I will mail Bill and ask.
I actually just noticed that PCP does have a template option to batch provision UDTs and ULTs.  I'm running 10.6.  I will report back if I get this working.
Just a small update... Confirmed with TAC that PCP's implementation of  UDT/ULT is too limited to be useful for bulk loading.
