Community Member
CUCM 10.5 - Can't Conference/Transfer Calls with Headset
Whenever the user is using their headset and the headset button is lit green, when pressing the CONF or TRANSFER softkeys, the phone just places the call on hold and does not provide a dial-tone.
If pushing CONF or TRANSFER while on handset or speaker, it works normally.
You should mention what phone
You should mention what phone model (and FW) you're using, and what headset, if you expect any assistance.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi,what kind of phones you
what kind of phones you have ?
I have a similar issue with 7941/7942/7970/7945. it was a bug with phone firmware.
you need only to upgrade to firmware 9.4(2).
Anas
Don't forget to rate the helpful posts
Hi,take a look to the below
take a look to the below thread
https://supportforums.cisco.com/discussion/12166856/problems-transferringanswering-calls-when-using-headset-79xx-phone-cscun26289
Anas
don't forget to rate the helpful posts
Community Member
Sorry about that. I am using
Sorry about that.
I am using 79XX with the 9-3-2 firmware.
Upgraded to new firmware and issue is now resolved.
894
