CUCM 10.5 - CCMUser page directory missing
Guys, would any of you off the top of your head know if 10.5 moved or got rid of the directory view for end users to see?   Our receptionist use to go to the following URL https://couccm01/ccmuser/showHome.do  in CUCM 9.2 and could see a list of the directory.   Now in 10.5, it takes you to the self care portal.
Thanks for any help.
http://www.cisco.com/c/en/us
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/10_5_1/CUCM_BK_CE15D2A0_00_cucm-release-notes-1051/CUCM_BK_CE15D2A0_00_cucm-release-notes-1051_chapter_01.html#CUCM_RF_DD060935_00
Directory Search in Self Care
The Directory Search option under User Options in releases before 10.0(1) has been removed from the 10.0(1) release onward. However, in the Self Care Portal, the same search capability is available under Contacts and Speed Dials, both of which a user can manually create.
Re: http://www.cisco.com/c/en/us
The search for the contacts is useless.
We could actually use the search that references the end users.  Contacts don't matter.
Is there a separate url?
That search option does look into the end users you have in your server, have you tried it?
java
if this helps, please rate
www.cisco.com/go/pdi
403
