CUCM 10.5 Locale Installer
Hi all,
I'm installing a solution with callmanager 10.5, on the cco there is only locale for release 10.0 that can't be installed on version 10.5, it give an error with major/minor version mismatch.
Can any one point me to the site to download the locales for version 10.5 ?
Patcbr600
1 REPLY
VIP Purple
Hi, I was referring the DOC
I was referring the DOC which talks about Local Installer as Optional and link for downloading but could not find anything.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/ucmapMigrate/10_5_1/CUCM_BK_M24251C0_00_migrate-procedure-for-cucm_1051/CUCM_BK_M24251C0_00_migrate-procedure-for-cucm_1051_chapter_00.html
Software Downloads
To prepare for the upgrade, download all of the listed software below from the following location:
http:/​/​software.cisco.com/​download/​navigator.html?mdfid=268439621&flowid=37562
  •  Cisco Unified Communication Manager Release 10.5(1) bootable image
  •  Cisco Prime Collaboration Deployment Release 10.5(1) vApp
  •  Cisco Unified Communication Manager Release 6.1(5) upgrade image or Release 7.1(5) upgrade image, depending on the version that you are using as an intermediate release during the upgrade process
  •  Phone firmware for Unified Communications Manager Release 10.5(1)
  •  Cisco Unified Communication Manager Release 10.5(1) device package
  •  (Optional) Cisco Unified Communications Release 10.5(1) Locale Installer for your local language
  •  Virtual Server Template (OVA file) for Unified Communications Manager Release 10.5(1)
  •  Cisco Unified Communications Manager Recovery software for your current Unified Communications Manager release
  •  For Unified Communications Manager Release 4.1(3), 4.2(3), 4.3(1) Cisco Unified Communications Manager Data Migration Assistant (DMA) 6.1(4) Cisco CallManager Upgrade Assistant 4.3(13
suggest opening TAC case.
regds,
aman
1331
