CUCM 10.5 problem with call transfe
Good morning
I have a problem with call transfer with consultation from an intern to another.
SIP phones used 7841
This schenario
Branch A
CUCM 10.5 at DATACENTER
RTR with gre-over ipsec TUNNELS to the DC
Pstn Gateway with 3 ISDN-BRI
Branch B
RTR-gre-tunneled over ipsec to DC
trace attachement
Problem
Receiving a call from the PSTN in Branch A, I try to transfer it to my colleague in the same office and after having talked with him, when i try to transfered the call, both ipphone remain blocked.
By tracer known that the error received is
MSG_LABEL: 488 Not Acceptable Media
This doesn't happen if from Branch A transfer to  Branch B
Can someone explain me why the phone of the Branch A not accept the media streams?
Thanks a lot
Hi Lorenzo.Just to make sure,
Hi Lorenzo.
Just to make sure, if you make a direct call transfer, does it work?
Can please send a full trace from when pstn  call arrives to Phone A?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,with the direct
Hi Carlo,
with the direct transfer there are no problems even if I use a SCCP phone I don't find some problem.
Attachment trace complete
Best Regards
Lorenzo
Hi Lorenzo.Thanks for sending
Hi Lorenzo.
Thanks for sending me the info requested.
Which signaling protocol are you using between CUCM and VG?
If SIP, please activate a debug ccsip message during the call transfer and post it here.
Carlo
Hi Carlothe VG uses H323
Hi Carlo
the VG uses H323 protocol to communication with the CUCM
Lorenzo
Hi Lorenzo.On your VG, add a
Hi Lorenzo.
On your VG, add a voice class codec with g711U/Alaw and g722-64 codec and add it to dialpeer pointing to CUCM.
Please try it and let me know.
Carlo
on the dial peer to the CUCM
Hi Carlo on the dial peer to the CUCM is already present the codec. I opened a tac and an engineer cisco asked me the sniffed traffic behind the phone. I will update the post as soon as I will get a response. Let me know if you have another idea to solve this problemi. Thank you Lorenzo
Hi Lorenzo.Can you please
Hi Lorenzo.
Can you please post full vg config in order to replicate it on my lab?
Carlo
Hi Carlo,I open a case with
Hi Carlo,
I open a case with Cisco have not been able to re solve the problem, requiring every time packet capture behind the phones.
when I discovered that the problem came from the SIP inspection that was the firewall in the data center I decided to update the firewall multicontext with the latest version, this has solved the problem. I do not have enough data to declare that the version of ASA is affected by bugs, but it is very likely
thanks for your time
Lorenzo
275
