CUCM 10.5 upgrade
I have a few questions that I would need your help with in regards to the 8.6 to 10.5 upgrade.
1. why do i have to install the cop file to resize the vdisk whereas i can easily do the same thing from the vmware thick client without installing that file?
2. should i choose the option to 'switch version' after the upgrade of each cucm servers or manually switch versions once all the servers in the clusters are done upgrading?
3. can i put any allowed mac address for the vmxnet3 adaptor once i change the allocation type to manual?
4. is there anything to worry after i change the guest os from rhel 5-32 bit to rhel 6-64 bit prior to upgrade and keep running the existing cucm version for sometime? does it continue to work?
Thank you so much,  Khanal
  • IP Telephony
98
