CUCM 10.5 Upgrade
I want to install a cop file and after a few seconds I've this error msg below. I can (of course) reload the CUCM server, but I will find another way to solve this issue....
Caan you help me ?
Thanks a lot
Christian.
Error Message (displayed on both web page and cli) :
(-The resource lock platform.api.network.address is currently locked by process 9801@SCUCM1 (NetMessageDispatch-21).  Please try again later-)
1 ACCEPTED SOLUTION
I just had a similar issue
I just had a similar issue trying to upload a new firmware cop file and just tracked down the process and restarted the services associated with that process....
From the CLI run "show process list"
track down the process that is reporting the lock.  In my instance it was process id 32264 which was associated with the DRF.
28114 /usr/local/Snmpri/bin/sappagt -pkg_conf -log_closefile -aperror -apemanate
32264 /usr/local/platform/bin/CiscoDRFMaster /usr/local/platform/conf/CiscoDRFMasterCfg.xml
 1900 /usr/bin/perl /usr/local/Snmpri/script/sapp_agent.pl 28114
I then restarted the DRF master and local service.
admin:utils service restart Cisco DRF Master
admin:utils service restart Cisco DRF Local
Then I retried my firmware upgrade with no issues.
Greg
What's your current version?
What's your current version??
And what COP file are you trying to install?
java
if this helps, please rate
www.cisco.com/go/pdi
Hi JaimeGracias for your
Hi Jaime
Gracias for your answer !
I want to install "cmterm-cupc-dialrule-wizard-0.1.cop.sgn" to a (10.5.1.10000-7) CUCM to use the application dial rules....
It seems there is an issue with the publisher because I've installed this cop file with success to the subscriber...
Thank you,
Christian.
Greg
Hi !It's Ok !Thanks a lot to
Hi !
It's Ok !
Thanks a lot to all !
Christian
facing the similar issue, but
thx.
Spot on.  Thank you!!!
Hi Greg,
Hi Greg,
I was upgrading Unity connection 10.5 to 11.0, Error message was same.
(-The resource lock platform.api.network.address is currently locked by process 9801@SCUCM1 (NetMessageDispatch-21).  Please try again later-).
So after restart this both services I able to upgrade without any issue.
Thanks for your help issue is fix.
with regards,
Vikram Pustake
Dimension Data India Ltd
2505
