CUCM 11.5 FCS - Deprecated Endpoints
CUCM 11.5 is now available on CCO software downloads as of today, the FCS build number is 11.5.1.10000-6 and can be accessed at the following:
https://software.cisco.com/download/release.html?mdfid=286306100&flowid=79971&softwareid=282074295&release=11.5%281%29&relind=AVAILABLE&rellifecycle=&reltype=latest
File: UCSInstall_UCOS_11.5.1.10000-6.sgn.iso
Release Notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/rel_notes/11_5_1/cucm_b_release-notes-cucm-imp-1151/cucm_b_release-notes-cucm-imp-1151_chapter_010.html
Imp Change:
As of Cisco Unified Communications Manager Firmware Release 11.5, the following phones are not supported:
  • Cisco IP Phone 12 SP+ and related models
  • Cisco IP Phone 30 VIP and related models
  • Cisco Unified IP Phone 7902
  • Cisco Unified IP Phone 7905
  • Cisco Unified IP Phone 7910
  • Cisco Unified IP Phone 7910SW
  • Cisco Unified IP Phone 7912
  • Cisco Unified Wireless IP Phone 7920
  • Cisco Unified IP Conference Station 7935
If you use any of these phone models on an older release of Cisco Unified Communications Manager and you upgrade to Release 11.5, the phone will not work after the upgrade completes.
Manish
Everyone's tags (1)
Purple
[+5] for sharing info.
regds,
aman
Also worthy of note is that
Also worthy of note is that CUCM IM&P in 11.5 will only work with Expressway V8.8 - Which isn't out yet!
GTG
Please rate all helpful posts.
That's an imp point, IM&P 11
That's an imp point, IM&P 11.5 is out and its compatibility with Expressway deployments needs to be ensured to prevent any issues.
Manish
Purple
I was unable to rate u on
I was unable to rate u on first discussion so , I rated this one.
regds,
aman
Thanks Aman, i wanted to
Thanks Aman, i wanted to share the point regarding deprecated endpoints in particular since this is a major change. A lot of installations still have these endpoints and we get a lot of requests checking their compatibility with CUCM 10.x and 11.x versions.
Manish
Community Member
Same for me since I wasn't
Same for me since I wasn't able to vote on the original post. Why is that?
Not sure why that's happening
Not sure why that's happening, thanks for the feedback though.
Manish
Hall of Fame Super Red
Hi Lisa & Aman,
Hi Lisa & Aman,
Just an FYI here.....original posts in the Discussion Level of the forums can never be rated as they are generally posing a question or query. Only Docs, blogs and videos posted by the OP can be rated :)
Cheers!
Rob
Community Member
Thanks for the information,
Thanks for the information, Rob. I'm still confused, though, because there are six 5-star ratings on Manish's original post. Why can some members rate the post and others can't?
Hi Lisa,
Hi Lisa,
You are most welcome my friend!
The ratings info you see on Manish's original post is actually a summary of ratings for the complete thread. If you look at the reply's from within the thread you can see that Manish got 2x5 point ratings on his second post, Gordon got 1x5 point rating and Jaime (Java) got 3x5 point ratings and that is why you see the summary on the OP of 6x5 star ratings.
On the individual posts like Java's you see - Overall Rating: 5 (3 ratings) for example to indicate that he got 3x5 point ratings.
Hope this helps!
Cheers!
Rob
Community Member
You explanation is very
You explanation is very helpful Rob (as are your posts - you've helped me several times in the past). Thank you!
Good to know such things in
Good to know such things in advance...+5 to Manish, Jaime &.Gordon for sharing this stuff !!!
Suresh
Community Member
Hi Gordon,
Hi Gordon,
is there a document saying that expressway 8.7.1 is not compatible with cucm IM & P 11.5.1.10000-6 upgrade available in CCO ?
Also, below document is talking about 11.5.1.10000-10 release but it is still not available yet
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/compat/11_x/cucm_b_cucm-imp-compatibility-matrix-11x.html#reference_E0BE64ED5B28FC5375A22B8E531C55A9
We will upgrade CUCM from 11.0 to 11.5 soon
Thanks in advance ..
Cheers,
MO Giacobbe
MCSD, SCJP, CCIE Collaboration #50401
The RN explain what Gordon
The RN explain what Gordon mentions, and x8.8 is now available on CCO.
The x8.8 compatibility note is ONLY applicable when being used for MRA.
The version mentioned in that doc is wrong, probably a typo, that version does not even exist, the FCS release was 11.5.1.10000-6 for CUCM/CUC and 11.5.1.10000-4 for IM&P, which is also different from the one mentioned in the RN.
java
if this helps, please rate
www.cisco.com/go/pdi
11294
