CUCM 2900 ISR G2 Support
I have a customer that is looking to update their voice gateways. We would like them to purchase 2900 series ISR G2 but we are unsure that CUCM 5.1 supports the new 2900 routers. Does anyone know if they are supported in CUCM yet, specifically CUCM version 5.1?
Are they any datasheets on Cisco that speak to this? Thanks for the help - much appreciated!!!!
Re: CUCM 2900 ISR G2 Support
No, support for ISR G2 starts with CUCM 7.1(3) which is currently available and also will be on 6.1(5) and 8.0(1) when released
You'll need to upgrade to use G2 ISRs
The RNs for 7.1(3) include the note for support.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Thank you for your response!
549
