Community Member
CUCM 3rd party Billing applications
Hi there,
I have a client who is running cucm 8.5 . Want a 3rd party application for CDR accounting.
Does not have much to spend for this purpose.
Can you recommend one ?
Also can you recommend few companies who can do this ?
What do you think about Calltrack ?
Si
Community Member
Hi Si,
Would something like this work for your customer?  CDR logs are externally FTP'd and processed in a SQL database (can use the free MySQL community edition).  This app can run queries and send scheduled emails of custom queries as well.
Chris
Community Member
Thank you
Community Member
Dear Chris
Need you help as how to load/setup this Sql process for monitoring these CDR's
kindly mail the same to me at teamglobal@gmail.com
Hall of Fame Super Silver
Si,
There is many vendors out there and you can search this forum for some examples. I've used ISI, eCAS and few others and they work fine, don't think they are cheap though.
Chris
Hall of Fame Super Red
Hi Si,
In addition to the great info from two of my faves Chris & Chris (+5 )
The list from Tere @ Cisco in this very recent thread is very extensive
have a look (she's done a fine job!!);
https://supportforums.cisco.com/message/3702926#3702926
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Community Member
Thank you guys, it is valuable information.
1453
