CUCM 4.2 integ with SIP Provider
I have terminated a SIP trunk on the voice gateway and configured it as CUBE. What configuration is required at Call manger 4.2 ?
An h323 or SIP trunk to your
An h323 or SIP trunk to your CUBE, bear in mind that the SIP capabilities on 4.x were a lot more limited to those of current releases.
java
if this helps, please rate
www.cisco.com/go/pdi
Can we use the existing H323
Can we use the existing H323 gateway in CUCM 4.2 and Create SIP dial peers with the ITSP.
If yes will it require any additional resoures.
Hall of Fame Super Silver
Sure, you will need to allow
Sure, you will need to allow sip to h323 connections under voip service.
Chris
I've created a route pattern
I've created a route pattern in CUCM 4.2 with wildcard 7!. This is pointing to a route list with H323 gateway.
On the gateway i've created a dial peer :
dial-peer voice 40 voip
description **Outgoing Call to SIP Trunk
destination-pattern 7.T
session protocol sipv2
session target ipv4: 1.1.1.1
dtmf-relay rtp-nte sip-notify h245-alphanumeric
codec g711ulaw
no vad
----------- Is it enough to match the sip voip dial peer on gateway.
Yes, assuming that´s what
Yes, assuming that´s what your telco is expecting to receive.
Try placing a call, if it doesn´t work, enable debugs to look at the failure cause.
java
62
