CUCM 4.2 - Number Range reporting
I've got a PSTN number range of a 1000 numbers with the dial plan listing a good 800+ dd's being used by either hunt groups or by users. I'm pretty sure some of these numbers are no longer being used but are still configured, is there any reporting tools which can tell me dd numbers which haven't routed calls over a time threshold... e.g. last 3 months...
Re: CUCM 4.2 - Number Range reporting
No, dates of last usage are not recorded
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
But you could use Cisco Unified Communications Manager CDR Analysis and Reporting to export cdr data and see if some line id's made calls in the last couple of months.
165
