01-07-2012 04:13 AM - edited 03-16-2019 08:51 AM
Customer had - MCS-7825-H1-IPC1, CUCM 4.1 version, we need to upgade now to CUCM 8.6 business edtion with new server [MCS7828I5-K9-BE8E]
If it possible to upgade CUCM 4.1 to CUCM business edtion 8.6 with "MIG-CUCM-USR-A ? or please light me the upgarde procedure for cucm 4.l to cucm business edtion latest version.
01-07-2012 08:03 AM
It depends on exactly what BE you're talking about.
You mention a 7828 so you might be going to 5K.
For that one there is no upgrade path to/from.
BAT is going to be your best friend here as you migrate the info.
Also, there's no direct upgrade path from any 4.X to any 8.X release even on standalone, you need to go thru 6.x or 7.x
The CSC FAQ on IP telephony covers upgrades, have you already reviewed that and the many other posts on the same subject that can be found on CSC?????
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
01-07-2012 08:46 AM
Customer setup is - MCS-7825-H1-IPC1 [ 400 - users setup ], plan to buy back the old server and submit business edtion 5k quote, please let me know how to quote for license in this design ?
Can use MIG-CUCM-USR-A in this design.
Or can we install CUCM 8.6, 7816 or 7825 equilvant HP or IBM server with 4GB ram & 160 GB HDD, it is allowed, cisco will support this ?
01-08-2012 09:43 AM
Whether your hardware supports CUCM 8.6 installation or not can be confirmed from this link http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/ps5748/ps378/prod_brochure0900aecd8062a4f9.html
If you find your server model in the list as supported for CUCM 8.6, you are good, else the model can be considered as unsupported. The link also has a pointer to HP/IBM equivalent supported servers.
Pls rate the post if it helps.
GP
