CUCM 5.0.4 security configuration fails
I am building a CCM 5.0.4 server on a HP DL380, at the end of the initial build it fails at -
"security configuration fails(1)"
The server is the first server in the cluster and is connected to a 3550-24POE switch for it's FA ports on the server.
Has anyone came across this issues and if they have, what was there fix?
James
Bronze
Re: CUCM 5.0.4 security configuration fails
It looks like you have plugged the cable to ILO port instead of NIC.
Did u manage to resolve this issue?
CI
Yes l managed to resolve this in the end. It was a while ago, but l think my fix may have been plugging both eth0 & 1 NICs into a switch.
James
102
