Community Member
CUCM 5.1.3 - DRS Backup failed
Hi, All!
We are using CUCM 5.1.3.7000 and have noticed, that after some system  patch was installed, built-in DRS has stopped to make sсheduled backups.
When we are trying to do manual backup, it says:
Failed to initiate backup. Backup failed, unable to create backup storage directory: /common/drf/(backup_data)/.
What might cause such bad behaviour?
Everyone's tags (2)
1 ACCEPTED SOLUTION
Community Member
Re: CUCM 5.1.3 - DRS Backup failed
Hi Shahnawaz,
                          i think you have to free up space in the DRF folder using the root account.You may want to open a TAC case for this as this requires root access.
Take the Root access and use these commands.
[root@ccmpub tacuser]# cd /common   ("tacuser" is the root account created )
[root@ccmpub common]# ls -l
you will find DRF directory with huge filesize.
drwxrwxrwx  32000 root     root       901120 Jun 24 02:00 drf
Go to that directory,
[root@ccmpub common]# cd drf
Delete the folders using the command rm -d -rf
Hope this helps.
Abdul
Please rate helpful posts !!!!
Rinat,
The error is because 91% of the server hard disk space is used & DRS is not getting enough space to create backup image. Pls vacate the disk & try to run the backup.
Even after having enough HDD space, if u continue getting the message, then look for DRS's permission to that folder where it creates backup image. Did the patch installation mess it up.
Pls rate the post if it helps.
GP.
Community Member
Hi, Gajanan!
Thanks for reply.
Could you please advice how to clear active partition effectively?
Checkout How to free up space on the hard disk
GP.
Community Member
Hi,  Gajanan,
In our case there is enough space on HDD still we are not able to take back.
Please let me know how to do DRS's permission to that folder ?
Community Member
Hi Rinat,
                Seems like you are hitting CSCsm33625 . Try to change backup path from /common/drf/(backup_data)/. to  /common/drf/(backup_data)./
Abdul
Community Member
HI Abdul,
No luck it don't work for me
please let me know how to do DRS's permission to that folder ?
I am getting following error in SDI logs
2012-04-23 17:39:44,467 INFO [NetMessageDispatch] - drfUtils:deleteFile: File deleted :/common/drf/dUmmI_Drf
2012-04-23 17:39:44,467 INFO [NetMessageDispatch] - drfutils.sftpOperation: executing sftp command: /usr/local/platform/cli_scripts/run_script /usr/local/platform/bin/drf_sftp.sh admin@192.168.42.68 rm /dUmmI_Drf no
2012-04-23 17:39:47,436 DEBUG [NetMessageDispatch] - drfUtils:sftpOperation: Successfully executed sftp command in allotted time
2012-04-23 17:39:47,436 INFO [NetMessageDispatch] - drfUtils:makeDirectory: Creating directory: /common/drf/2012-04-23-17-39-47/
2012-04-23 17:39:47,449 DEBUG [NetMessageDispatch] - drfUtils:makeDirectory: Error - directory creation failed for: /common/drf/2012-04-23-17-39-47/, stdErr: /bin/mkdir: cannot create directory `/common/drf/2012-04-23-17-39-47': Too many links.
Waiting for your reply.
Thanks in advances
Community Member
Hi Shahnawaz,
Hope this helps.
Abdul
2390
