Silver
CUCM 5.1 - Permissions
I'm having an issue on a 5.1 cluster under end user config. The "View Details" link under "Permission Information" (for Groups and Roles) doesn't do anything.
I've tried firefox, IE, and safari and nothing happens when I click on the "View Details" links.
Any ideas?
thanks,
Will
Re: CUCM 5.1 - Permissions
Hi Will,
Try to select the Groups/Roles then click on the "View Details"
Hope this helps
Mark
Silver
Still nothing. The only workaround that I've found is to go into the groups and add the users that way.
It's kind of a pain, but there aren't many of these types of changes needed so it's bearable. I was just curious if anyone had found a better workaround or if anyone else is actually seeing this bug.
thanks,
Will
97
