Silver
cucm 5.1 switched versions
I have a system whereby the S/W was only installed on one "half" of the cucm. I need to have it on both so I can switch versions. How do I resolve this?Do I switch versions on the the non-working half and then install the sw/a again ? - many thanks
1 REPLY
Gold
Re: cucm 5.1 switched versions
Switch version is not designed to work as a backup. Switch version is revert to a previous version. So, if you would like to have this option available, you should download the latest SR/ES for the version you have an install that on the box. That would give you the option of switch version to the current version that you have.
Hope this helps
117
