CUCM 6.0(1) - cluster
andrejrudas
I have just installed cluster contain from 2 servers with CUCM 6.0(1). First (cm-1) as primary node, second (cm-2) as subsequent node. I requested and received licenses for each server. During license request for subsequent server, I used MAC of cm-2. But now publisher (cm-1) don't want to take that license.
Do I need license for subsequent server?
If, yes, should I use during registration MAC of Primary (Publisher) server?
And finally how can I request and change that license to right one?
Thanks in advance,
Andrew
Jon Nelson
Level 3
Level 3
The licenses for both nodes should be registered to the MAC address of the Publisher.
Send an e-mail to licensing@cisco.com or open a TAC case to request that the license file that is currently homed to the Subscriber be re-homed to the Publisher.
Jon
Thanks a lot, Jon!
Chris Deren
All of your licenses should only reference the PUB MAC. I suggest you open a case with cisco licenensing licensing@cisco.com and have them convert the second license to NODE license.
Chris
