Community Member
CUCM 6.0 BE Help Files
I have installed CUCM 6.0 BE and when I loggin and click help I just get a 404 error.
HTTP Status 404 - /Help/en_GB/ccm/index.html
Strangel the help for Unity Connection works fine.
Any ideas ? Do I need to install the help separately ?
Pat
Community Member
Re: CUCM 6.0 BE Help Files
Hi Pat,
Same here - new 6.0 BE install and no help files. Of course you don't have to install help files separately. Looks like a bug!
Cheers,
Vlad.
Community Member
Yes, it is a bug CSCsi04922 "Http error found on help page of all asociated items". It's fixed, but not clear what interim version.
Cheers,
Vlad.
Community Member
I have same errors that I get a 404 error on help at CUCM 6.0.
Did you get fixed it up?
Community Member
The workaround is to replace locale url to US one.
For instance if you have en_UK in the URL replace it with en_US.
Cheers!
Vlad.
Community Member
Cheers!
Vlad.
120
