CUCM 6.0 inbound call fail with h323 gateway
Hi all,
i'm setting up a cisco 2821 as h323 voice gateway for a CUCM 6.X (i'md oing a migration from cucme to cucm).
This is the configuration h323 gateway config:
--- for inbound call---
voice class h323 1
h225 timeout tcp establish 3
dial-peer voice 69 pots
incoming called-number .T
direct-inward-dial
dial-peer voice 223 voip
preference 1
destination-pattern 223
voice-class h323 1
session target ipv4:10.1.10.10
dtmf-relay h245-alphanumeric
codec g711ulaw
ip 10.1.10.10 is the cucm ip address.
______________________________________
---for outbound call---
all is working fine!
So, if i try to call 223 number, CUCM reject call.
223 is a directory number registered on CUCM that is working fine for outbound call.
Any idea?
1 ACCEPTED SOLUTION
Re: CUCM 6.0 inbound call fail with h323 gateway
make sure you're sending the call from the IP configured under CUCM
h323-gateway voip bind srcaddr ip_address
h323-gateway voip interface
CUCM only accepts calls from IPs he recognizes for H323
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
This was helpful for resolve my issue!
h323 gateway configuration was right!
Thank you very much
Diego
Also make sure the Calling Search Space for the h323 gateway in CM can see the Partition where the DN 223 is in.
I didn't configure any partition or calling search space. Is this mandatory?
Diego
Hi Diego
How many interfaces do you have on your H.323 gateway? If you don't configure the "h323-gateway voip bind srcaddr" command on the Interface with the IP configured in CUCM, the gateway will use the otugoing interface for the source IP.
Sometimes also a Reset on the H.323 Gateway Config on CUCM helps ;-)
Have you tried to "debug cch323 h225"?
Stefan
Hi stefan,
this is the debug:
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_call_setup_normal: SETUP_NTF_TIMER is not running. Continue processing.
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_IDLE state
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_SETUP while at state H225_IDLE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/check_qos_and_send_setup: Setup ccb 0x48D78A38
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_FS_SETUP while at state H225_IDLE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/idle_fsSetup_hdlr: Setup ccb 0x48D78A38
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/copy_token_from_ccb: copy_token_from_ccb: Entered
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup:
generic_send_setup: is_overlap = 0, info_complete = 0
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: sending calling IE
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: ====== PI = 3
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: Send infoXCap=128, infoXRate=16, rateMult=0, xMode=128, info_layer1_prot=163
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/generic_send_setup: src address = 10.1.10.1; dest address = 10.1.10.10
gatewaypd#
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_IDLE state to H225_REQ_FS_SETUP state
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_CONN_LOST while at state H225_REQ_FS_SETUP
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/run_h225_sm: Received event H225_EV_RELEASE while at state H225_REQ_FS_SETUP
Jan 12 10:11:23: //5440/CEBB6946BA7C/H323/cch323_h225_set_new_state: Changing from H225_REQ_FS_SETUP state to H225_IDLE state
Diego
944
