CUCM 6.0 - Messaging Interface not able to run
Anytime I try to start the messaging interface it will fail, I haven't been able to get any logs or reason as to why it fails. Anytime I try to restart it then it will still fail. Any ideas or places to look?
1 REPLY
Re: CUCM 6.0 - Messaging Interface not able to run
If you do not have an SMTP host configured, it will not start up. If you are not using SMTP with CM6, I would just leave it off.
Configure SMTP in the OS (add server,etc)
139
