Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
CUCM 6.0/Phone registration rejected if Pub is not in CMG
Running CM6.0 and phones will have their registration rejected if the PUB is not in their CMG. Even if a phone has previously registered, and I modify the CMG to take out the PUB, on reset, the phone gets registration rejected.
Green
Re: CUCM 6.0/Phone registration rejected if Pub is not in CMG
Are they getting proper configuration file from TFTP?
Any Error under status messages?
Have you restarted TFTP and disable caching and create all configuration files?
Looks like a Change notification problem if network settings are fine
How many servers?
1 pub and 3 subs right now and all subs have the same issue. Right now the pub is defined as the TFTP server and yes, they get their proper tftp config file.
I'will try restarting TFTP server tomorrow - but as the subscribers aren't defined as their tftp server, will that possibly help?
Is CallManager service running on your subs?
Yes - and we have Unity connection ports registered to them. The phones won't.
506
