CUCM 6.0 user log
Hello.
Is there a possibility in CUCM 6.0 to see any changes in configuration that was made by other administrators?
Thanks.
Everyone's tags (1)
Re: CUCM 6.0 user log
Changes from the CLI - yes.
Changes from the CCMAdmin web portal - not really.
You can piece together certain things by using the tomcat logs and other trace files but it would be a very time consuming task that would produce very little information.  Even with said information, you would have to infer quite a bit.
In 7.1(2) and later, Cisco has introduced a better auditing mechanism.  I did a write up on it here:
http://www.netcraftsmen.net/resources/blogs/audit-logs-on-cucm.html
Not immediately helpful I know, but maybe something to ponder.
HTH.
Bill
Please remember to rate helpful posts.
HTH -Bill (b) http://ucguerrilla.com (t) @ucguerrilla
Thanks very much.
No problem.
Bill
527
