CUCM 6.1.2.1002-1 - Problems adding SNMP destination
I'm trying to add an SNMP destination to a CUCM server. I get to the step where it asks you to choose a community string, but it doesn't list any of the strings in the system in the dropdown menu. If I try to add a new one though the destination page, it adds it but when it comes back to the notification page the new one still isn't in the dropdown menu. Screenshot attached shows what I mean if I wasn't clear. Has anyone run into this?
1 ACCEPTED SOLUTION
Re: CUCM 6.1.2.1002-1 - Problems adding SNMP destination
Only community strings with minimum notify privileges (ReadWriteNotify or Notify Only) display. If you have not configured a community string with these privileges, no options appear in the drop-down list box.
java
if this helps, please rate
java
www.cisco.com/go/pdi
java
java
that worked, thanks very much
145
