06-02-2009 08:11 AM - edited 03-15-2019 06:19 PM
Dear Networker,
We have upgraded CUCM from version 4.1 to version 6.1. The upgrade was done successfully.
After the upgrade , of the CUCMwe wanted to make an upgrade of the ATAs firmware.
We have uploaded the firmware (3.2(4)) successfully on the CallManager cluster. The issue is that the ATAs did not upgrade their firmware!
we have restarted the tftp server on the callmanager server, we even restarted the whole cluster but still the issue persists!
It's the first time that i see such issue.
Can you please give me an idea about this issue and how could be resolved?
Thanks in advance.
Regards.
06-26-2009 12:41 PM
What version of CUCM do you have?
06-26-2009 02:30 PM
06-26-2009 02:33 PM
The IP address of the ATA (in the Wireshark traces) is 172.29.1.195.
The CCM TFTP Server IP address is 172.29.0.1
Thanks in advance.
06-10-2009 02:36 AM
It appears that ATA 3.2(4) does not like CUCM 6.1. I have upgraded my ATAs to 3.2.3, which is compatible with 6.1 and they work a lot more reliably with fax passthrough. I still have a TAC case open on this so will post again if a resolution is possible on 3.2.4.
06-10-2009 07:21 AM
OK thanks for your help.
07-09-2009 01:08 AM
I was able to upgrade to Version 3.2.4. I used the Phone based Method.
1. Download the ZIP File for 3.2.4 SCCP.
2. Run sata186us.exe -h<
3. Attach a Phone to the ATA on Port 1. Follow the Steps printed on the console during lauch of sata186us.exe in Step 2.
Thats all.
Thomas
07-23-2009 09:32 AM
Did anyone manage to find out why tftp upgrades from callmanager didn,t work. I have the same problem and i can't use the sata186 method as all sites are remote..?
07-24-2009 09:04 AM
This is bug in the CUCM, what you can do is create a new CUCM group and one DP add all the ATAs there and do the firmware upgrade.
07-25-2009 03:03 AM
Thanks for that Info. Can you tell us in which version this bug will be fixed or at least the bug ID if it is public ?
Thomas
07-26-2009 04:10 AM
The bug is not Fix yet.
Bugs:
CSCsr45184
CSCsd44357
11-24-2009 01:03 PM
Hi, can you tell me how this helps the ATA code upgrade? I have the same problem and want to upgrade the code on my ATAs.
What does the new CUCM group and Device Pool do to help?
Thanks, Jim
11-25-2009 07:20 AM
The new CUCM group and the device pool is one of the work arrounds that we have in order to fix the issue. Also you could try to use and external TFTP server for this or upgrade the code manually, or finally follow the process that is listed under the bug description.
