Community Member
CUCM 6.1(2) BAT - a way to associate user&device for ccmuser?
Is there a way during phone/user BAT input, to associate the userid to device for ccmuser phone manipulation? I cannot find a field that performs that function. Primary device does mobility, but that is it.
THANKS!
1 REPLY
Bronze
Re: CUCM 6.1(2) BAT - a way to associate user&device for ccmuser
you should down load the sample CSV file and make sure the field is available or not. If that field is there then you can.
251
