CUCM 6.1.2 BAT Issue
CUCM 6.1.2. trying to update phones IP Services using BAT. I have created a phone template and subscribe to the EMlogon Service we have for Extension Mobility. Update using a query for 90 new phones we have auto registered. Only this field being updated.
Applying IP services for the phone template. Job gets scheduled OK and starts to process, but every phone is failing with an error:
DEVICENAME Could not position within a table (informix.telecastersubscribedservice).BAT Exception : UpdatePhone::getTeleSubServicesPkids
Any one had this issue before and got a resolution to this. Have done some searches on CCO but not found this error. Also did a Google search and had limited results around the Informix DB runing out of Space???
BTW - Other BAT updates on other fields are working OK.
Many thanks
1 ACCEPTED SOLUTION
Bronze
Re: CUCM 6.1.2 BAT Issue
It's a bug:
Assign IP Phone Services
Add All Services From This Template
From the drop-down list box, choose the template that contains list of services that you want to update the phones with.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03updph.html#wp1342091
CSCea28827 Bug Details
BAT to support subscribing users to PAB and Fast Dial Services
Symptom:
Cannot subscribe the users to IP Phone services like Personal Address Book
and Fast Dials through BAT. This applies to any IP Phone services.
Conditions:
The problem exists in all the BAT versions
Workaround:
None
After adding the Phones/Users through BAT, one has to manually
go to each user page and subscribe the users/phones to these services,
enter the PIN, User ID manually.
Please rate if this helped.
1 REPLY
Bronze
It's a bug:
Symptom:
Conditions:
Workaround:
None
140
