CUCM 6.1(2) to 6.1(3) upgrade advice
Hi All
I want to upgrade my cucm 6.1(2) to 6.1(3) i have downloaded two very large files with .iso_part1of2 extensions. Do i need to remove the extension from the file and leave just .iso ?
i looked for support documentation but cant find anything useful other than telling me to create a ISO DVD for the uprade which failed when i tried (im using Nero)
any help appreciated
regards
Colin
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CUCM 6.1(2) to 6.1(3) upgrade advice
Hi Colin,
At the end of the day, I believe the file should look like this;
UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
Upgrading From Cisco Unified Communications Manager Release 6.1(1x) or higher to Release 6.1(3) by Using the UCSInstall File
Because of its size, the UCSInstall iso file, UCOS_6.1.3.1000-16.sgn.iso, comprises two parts:
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2
•UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2
Procedure
Step 1From www.cisco.com, download the two UCSInstall files.
Step 2Execute one of the following commands to reunite the two parts of the file.
NoteThe 6.1.3.1000-16 build represents a non-bootable ISO that is only useful for upgrades. You cannot use it for new installations.
a.If you have a Unix/Linux system, cut and paste the following command from this document into the CLI to combine the two parts:
cat UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 > UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
b.If you have a Windows system, cut and paste the following command from this document into the command prompt (cmd.exe) to combine the two parts:
COPY /B UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part1of2+UCSInstall_UCOS_6.1.3.1000-16.sgn.iso_part2of2 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
Step 3Use an md5sum utility to verify that the MD5 sum of the final file is correct.
417c262e5706103c4e75a825e1d5d902 UCSInstall_UCOS_6.1.3.1000-16.sgn.iso
From these Release Notes;
http://www.cisco.com/web/software/282074295/24094/ciscocm-6-1-3.Readme.pdf
Hope this helps!
Rob
Hi Colin,
Procedure
Hope this helps!
Rob
Your a legend Rob
Colin
Hi Colin,
Hahaha......thanks buddy! Glad to be of some help here.
Cheers!
Rob
Hi Colin,
be aware that CUCM 6.1(3) is not upgradable to CUCM 7.0 at this time.
Reg.
Johann
627
