CUCM 6.1.2 - violation of security protocols ?????
We have a CUCM 6.1.2.1000-13 and want to add an enduser and a device.
But these actions failed with an errormessage (error.jpg and user.jpg)
The error is displayed when I try to add the enduser and/or while adding a device or deviceprofile.
The name "Memarmoshrefi" may not be in the description field or namefields!
If we remove the last two letters "FI" it works!
What wrong?
We testet this on several CUCM's with the same results!
Dirk
1 REPLY
Re: CUCM 6.1.2 - violation of security protocols ?????
CSCsu99802 Bug Details
End User Page Error: Access to the requested resource has been denied
Issue:
Customer has a user with a last name of Shreffler. When adding this user to the CUCM End user page the CCM errors out with the following message:
"Access to the requested resource has been denied.
The attempted action was a violation of security protocols and will not be allowed. Please try another action."
Cause:
If any text field on the Add End User Page contains the string HREF the above error will be generated.
Further Problem Details:
This problem effects all CUCM pages that allow text input.
Work Around: Try not to use HREF withing the string being added
Versions Effected: All CUCM 6.X.
Fixed-In
6.1(2.9901.207)
7.1(0.39000.101)
7.0(1.30010.22)
you need to migrate to 7.(x)
java
if this helps, please rate
java
www.cisco.com/go/pdi
339
