10-19-2009 01:59 PM - edited 03-15-2019 08:08 PM
remote refid st t when poll reach delay offset jitter
127.127.1.0 127.127.1.0 10 l 61 64 1 0.000 0.000 0.008
192.77.15.20 .LOCL. 1 u 18 64 1 0.581 -138070 10.449
unsynchronised
time server re-starting
polling server every 16 s
Current time in UTC is : Mon Oct 19 21:49:54 UTC 2009
Current time in America/Chicago is : Mon Oct 19 16:49:54 CDT 2009
NTP is synching to the server, however the phones are a full 2 minutes off from the network time. I'm guessing it has to do with the large offset value.
Any ideas on how to fix this error?
10-19-2009 04:53 PM
Try to reset the phone affected and restart the tftp service,
10-19-2009 07:19 PM
All phones are effected. All have the same time, that matches what the "utils ntp status" message result above shows.
My problem is that the callmanager is a off by a little over 2 minutes when compared to the ntp server its receiving the time from. All other devices that sync to that ntp server have the same time, except for the callmanager which is off by 2 minutes.
Thanks!
10-19-2009 09:50 PM
So call manager is not in sync with NTP server, try this
login as the root access
. /etc/init.d/ntpd stop
. vi /etc/ntp.conf
. remove "ignore" from "restric default ignore"
. /etc/init.d/ntpd start
