Community Member
CUCM 6.1.4 Replication state 4 and 3
Hello all,
I am having replication state 4 with one subscriber and 3 with al the others. I have tried utils dbreplication reset and repair, each time after utils dbreplication stop in all subs and then in pub. Any idea in how to recover?
One sympton, is that the same list of servers does not appears in the result of show tech dbstateinfo in all the servers.
Thanks for your help
Bronze
Re: CUCM 6.1.4 Replication state 4 and 3
Get root access for all the servers. Update the hosts with right entries. reset cluster.
make sure you understood this....
utils dbreplication clusterreset
This command resets database replication on an entire cluster.
Command Syntax
Usage Guidelines
Before you run this command, run the command utils dbreplication stop first on all subscribers servers, and then on the publisher server.
Requirements
Command privilege level: 0
Allowed during upgrade: Yes
utils dbreplication dropadmindb
This command drops the Informix syscdr database on any server in the cluster.
Command Syntax
Usage Guidelines
You should run this command only if database replication reset or cluster reset fails and replication cannot be restarted.
Requirements
Community Member
Thanks for the answer. Suppose I do not understand the root access solution ;-) . Could it be posible to delete from Cluster and poweroff the Subscriber with 4 status, and then, reinstall it as if a new adition of subscriber where done? Then, it will be updated in all the Subs and Pub and the info about others will be downloaded to it during installation. What do you think about this?
Bronze
You can do this but dont u think its a long procedure for you?
Community Member
Finally, there was a problem with connectivity between 2 of the 3 subscribers. Once solved, it started working after rebooting publisher.
In cli, the command "utils diagnose module validate_network" is very usefull to look for this types of errors.
Thanks for your help.
403
