Community Member
CUCM 6.1.5 hard drives copy
Hi all,
I would like to have a copy of hard drives of my CUCM 6.1.5 for store it in another place.
I found this article related to CUCM 7.1.2 where is indicated the procedure to change a failed hard drive: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/trouble/7_1_2/tbsystem.html#wp1190377
In this guide there is clearly write that this procedure do not apply and are not supported if I attempt disk replacement for a disk that is not detected as failed.
My questions are:
- I didn't find a similar procedure in troubleshooting guide for CUCM 6.1.5, but I think that I can apply the prcedure of CUCM 7.1.2 because the raid is indipendent from OS/CUCM version. Or I'm wrong?
- Someone did this procedure without having a broken disk? It works?
- Someone knows other procedure in order to have a copy of hard drives of my CUCM 6.1.5 for store it in another place?
Any answers will be highly appreciated.
Regards.
Danilo.
1 REPLY
That applies to ANY of our CUCM appliances, we do not support pulling out HDDs as a backup/recovery method.
We only support swapping the HDDs when they fail.
All of our products provide a way to backup the configuration.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
239
