01-22-2009 02:56 PM - edited 03-15-2019 03:43 PM
Where does the data for speed dials and other lists that the AC user personalizes get stored?
Solved! Go to Solution.
01-22-2009 03:05 PM
The txt file is stored here.
C:\Program Files\Cisco\Unified Communications Manager Attendant Console\userlists for the corp directory.
You can actually export the speed dials by going to File-->Export Speed Dial
Edit: Just found the speed dial location its here:
C:\Program Files\Cisco\Unified Communications Manager Attendant Console\data\
This houses a globalsetting.xml file and then each AC user that has logged on.
Matt
Matt
01-22-2009 03:05 PM
Matt
Matt
01-22-2009 03:53 PM
Matt,
Right on.
Now that I am looking at AC again after a long while I remember seeing the data folder before.
Also the export/import speed dial features are just what I needed.
Thanks!
