CUCM 6.1 Backup!!
Hi ,
How to take CUCM 6.1 Backup?
Manish
Hall of Fame Super Red
Re: CUCM 6.1 Backup!!
Hi Manish,
In CUCM 6.x this is done via the "Disaster Recovery System", pretty cool! Here is a look at the related info;
The Disaster Recovery System (DRS), which can be invoked from Cisco Unified CallManager 6.0 Administration, provides full data backup and restore capabilities for all servers in a Cisco Unified CallManager cluster. The Disaster Recovery System allows you to perform regularly scheduled automatic or user-invoked data backups. DRS supports only one backup schedule.
The Cisco Disaster Recovery System performs a cluster-level backup, which means that it collects backups for all servers in a Cisco Unified CallManager cluster to a central location and archives the backup data to physical storage device.
When performing a system data restoration, you can choose which nodes in the cluster you want to restore.
The Disaster Recovery System includes the following capabilities:
A user interface for performing backup and restore tasks.
A distributed system architecture for performing backup and restore functions.
Scheduled backups.
Archive backups to a physical tape drive or remote sftp server.
The Disaster Recovery System contains two key functions, Master Agent (MA) and Local Agent (LA). The Master Agent coordinates backup and restore activity with all the Local Agents.
The system automatically activates both the Master Agent and the Local Agent on all nodes in the cluster.
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/6_1_2/DRS_CUCM/drsag612.html
Hope this helps!
Rob
Hi Rob,
I am facing an error while i am taking the CUCM backup using DRS. Error is: " SFTP Transfer failure: No enough disk space available" But i have plenty of space available in SFTP server.
Please advice
Nahas
Hello Nahas
I got the same issue as you.
I am not able to find any answer in the cisco documentation.
What did you do to progress ?
yours sincerely
Jean
Hello jean,
No updates on this.
Which SFTP you are using? Im using core ftp light.
Nahas
Hi, I find freeFTPd works best with CUCM. Haven't had any issues with that.
Bonjour Nahas
I use freeFTPd version 1.0.11
is it ok for you with core ftp light ?
thank you for your help
Jean
Disaster Recovery System Administration Guide for Release 6.1(2)
java
if this helps, please rate
java
www.cisco.com/go/pdi
Thank a ton for your help!!
Manish
1330
