CUCM 6.1 - BAT Export issue
Hi guys,
I doing some research on the BAT Export tool on our CUCM. But after I succesfully scheduled the job of Exporting all the Server/Call Routing/Media Resource items. I see in the job schedular that the job is Completed, but I can't see it in the list of Upload/Download Files.
Could it be that I'm running into a bug or something? Cause I can not see that I'm doing something wrong :S
System version: 6.1.1.2000-3
Guide used: http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t13cnftl.html
Kind regards,
Paul van den IJssel
Digacom
  • IP Telephony
Re: CUCM 6.1 - BAT Export issue
Hi Paul,
I use the same version, no problems here.
I selected all items, entered a name and clicked on submit.
After a while, selected the according completed job id containing the logfiles of all exported items which were present in the created *.tar file under Upload/Download files. No erros/failures mentioned. Does your job contains failures?
Try to export some of the items, and see if the behaviour changes.
Eric
Hi Eric,
I've allready had several succesful Exports. Some containing only one item, some all of the items.. but no tar's in the download folder :(
I'll give the CUCM a swing this evening and see what'll happen.
I'll keep you informed.
Paul van den IJssel
Digacom
ps.: alvast een goed weekend ;)
129
