CUCM 6.1 Billing Server Issue .....
We are using CUCM version 6.1.3.1000-16. We have configured a billing server over SFTP. It is working fine but some time we faced the issue of missing records on the billing server for a particular time period. As per our experience, if there is some issue on the billing server (Network issue, FTP / SFTP service down) CUCM does not store these CDR files to send them after the restoration of the billing server.
·         Is there any option in configuration so that CUCM can resend the CDR files after the restoration of the billing server or the Network connectivity?
·         Does CUCM store these logs so we can read them and manually dump the CDR files to the billing server.
Everyone's tags (3)
2 ACCEPTED SOLUTIONS
Re: CUCM 6.1 Billing Server Issue .....
CUCM does hold the flat files in case of network outage and then sends them when it's back online.
Other than that it means access the files via CLI.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Use the commands:
file list
to view the structure
file get
to retrieve files
java
java
java
java
Thanks for your reply.
Can you please tell me the procedure to get these files using CLI.
Use the commands:
file list
file get
to retrieve files
java
java
642
