CUCM 6.1 DHCP Lease Usage
After configured the DHCP server and DHCP subnet on CUCM, how do you monitor the lease usage by the end devices?
1 ACCEPTED SOLUTION
Re: CUCM 6.1 DHCP Lease Usage
Just the other day someone posted this
How to check DHCP leases status on cisco CCM 6x
http://pushkarbhatkoti.wordpress.com/category/ccm-5x-6x-7x-stuffs/how-to-check-dhcp-lease-on-ccm6x/
Please search previous posts using the Search NetPro function to make sure no one has asked the same thing and the answer is already there
java
if this helps, please rate
java
www.cisco.com/go/pdi
1 REPLY
java
java
357
