Community Member
CUCM 6.1 inactive partition upgrade
Hi, will CUCM 6.1 is still running when upgrade/patch the CUCM on its inactive partition? Thanks
1 REPLY
Re: CUCM 6.1 inactive partition upgrade
only the version from the active partition will be running at any given time in a CUCM version, inactive version is there only in case you need to do a rollback
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
270
