03-06-2009 06:47 AM - edited 03-15-2019 04:40 PM
I am trying to install CUCM 6.1.1 for our lab environment using VMWare. However I am coming to a error message every time, "Could not allocate requested partitions. Partitioning failed: Could not allocate partitions as primary partition. Press OK to reboot". Has anyone come accross this error message? What should I do correct the issue? I have allocated 1 GB memory and 80 GB HD space. Please advise.
Chandrasen
03-06-2009 08:19 AM
Hi!
Installation of CUCM on a VMware server is unsupported, but can you please make sure that the virtual disk type is IDE and not SCSI (which is the default). Then try again.
Hope this helps!
Teresa.
03-06-2009 08:32 AM
Hi Teresa,
Thanks for the reply. In fact this is for an in house installation for our lab and will be used for training and customer demos.
I changed the disk type to IDE but I am getting the same error message. Any other ideas?
Chandrasen
07-02-2009 11:29 PM
HI,
You probably figured this out by now. You need more disk space.
HTH,
Randall
