Community Member
CUCM 6.1 license file removal
How do I remove an old phone license file from my system? I goofed when I was adding 20 new phone licenses and they reissued all of my original phones again. Now I have double the node licenses and almost double the phone license.
--Patrick
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: CUCM 6.1 license file removal
Hi Patrick,
Here are the details :)
file delete
The file delete command includes the parameters dir tftp and license. The file delete command deletes one or more files.
Command Syntax
file delete
dir tftp directory [detail]
license filename [detail]
Parameters
•dir tftp directory deletes the TFTP directory specified by directory. You cannot enter the wildcard character (*) in directory.
•license filename deletes the license file that is specified by license. You can enter the wildcard character (*) as filename to delete all the license files.
Options
•detail-Displays details
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/6_1_2/cucm-rel_note-612.html#wp412067
Hope this helps!
Rob
Hi Patrick,
file delete
Command Syntax
file delete
Parameters
Options
Hope this helps!
Rob
Community Member
Thanks Rob,
That did the trick.
--Patrick
Community Member
Is there a way to get CCM to use the original node license that is installed during installation? Using your steps I was able to delete the licenses that I needed to, but now it's saying that I don't have a node license when there was one automatically there when I installed the server.
Community Member
I also have the same problem with you. I had deleted the license following the steps in the discussion. But the original node license file is gone too.
So anyone have got a way to get the original no license back.
Please!!! I need it urgently!!!
you cannot get it back, once you install a permanent licence the one that came with the server is gone
you need another permanent license
java
if this helps, please rate
java
www.cisco.com/go/pdi
595
