Community Member
CUCM 6.1 ROLM 9751 Integration
Hello
I've been tasked with a CUCM/ROLM integration. I need to do extension to extension dialing between the two systems and possibly use the ROLM as the PSTN gateway for the CUCM. I have done an NEC CUCM integration for ext2ext but never touched a ROLM. Does anyone now where to start with a project like this? Does the ROLM 9751 support a T1 QSIG integration? Has anyone ever performed an integration like this?
Thank you
Community Member
Re: CUCM 6.1 ROLM 9751 Integration
We are doing one, but having problems with caller ID and also with trunk to trunk transfers. What issues did you run into?
Kevin
No qsig on that version of the Rolm. It's only a straight T1 CAS. No caller ID.. which stinks. I dont think they have a qsig package if they do, its probably really expensive!
275
