06-03-2008 02:04 PM - edited 03-15-2019 11:02 AM
Real quick question. Can someone post the URL to the Server Compatibility chart for CUCM 6.1? I've searched endlessly tonight and I just can't seem to find it! It's driving me mad! :)
Thanks in advance.
Solved! Go to Solution.
06-03-2008 03:11 PM
Hi Dominic,
Here you go my friend :)
Cisco Unified Communications Manager Server Support Matrix
Hope this helps!
Rob
06-03-2008 03:11 PM
Hi Dominic,
Hope this helps!
Rob
06-03-2008 03:50 PM
The easiest way to find something on Cisco's website is to use the search keyword in google.com. You will reach there faster than you would think. Cisco;s new search engine interface looks great, but the links it return are crappy after the recent changes they made...
