CUCM 6.1 with Extension Mobility
I have a dumb question. How do I find out what device an Extension Mobility user is logged into in CUCM 6.X?
Glenn
Re: CUCM 6.1 with Extension Mobility
No question is dumb. Go into User Management > End User > put in the extension and then hit find. Then at the top right side, scroll down to related links and click on dependency records. Click go and then you will click on phone and that should tell you the device the user is logged into.
I hope this helps.
Donna
device -> phone -> related links -> Actively Logged In Device Report
java
if this helps, please rate
java
www.cisco.com/go/pdi
I knew it was something easy. Thanks very much.
Glenn
204
