Community Member
CUCM 6.1 with ICT and H225 GK Trunks
I have come across an issue and wanted to see if anyone else has seen the following:
Configuration - CUCM 6.1 cluster with ICT to CCM 4.13 cluster. Also, have GK H.225 trunks configured to a GK cluster.
The problem is that when I make any change on either the Inbound Calls for the ICT or H225 trunk configuration (signficant digits/inbound CSS), the change is reflected across both trunk types. The actual configuration items do not update (CSS will be different on both trunk types), but their behavior changes to the last configuration change regardless of which trunk is being configured.
I have also seen this issue with the CCM 4.13 cluster.
I would hope that the two trunk types can have seperate configurations.
Thanks.
1 REPLY
Silver
Re: CUCM 6.1 with ICT and H225 GK Trunks
Could you provide the details of these debug commands
debug h225 ras
debug cch323
debug h225 asn1
206
